散装线材 - 视频 | RG HD-SDI/HDTV 广播 视频 & 卫星线材
SOMMER CABLE - SC-RG CLASSIC BROADCAST SERIES (RCBS) | 屏蔽层因数 | 100 % | 温度范围 | 最低-30 °C | 温度范围 | 最高70 °C | 包装 | 100 m/500 m/1000 m roll | 浪涌阻抗 | (+/-1 %) 75 Ohm |
类型: | RCBS 0628 | RCBS 0628 | RCBS0837 | RCBS0837 | RCBS1048 | RCBS1048 | RCBS 1670 | RCBS 1670 | RCBS 0628 | 结构 | 02YS(ST)CH0.6/2.8 HD-SDI | 02YS(ST)CH0.6/2.8 HD-SDI | 02YS(ST)CH0.8/3.7 HD-SDI | 02YS(ST)CH0.8/3.7 HD-SDI | 02YS(ST)CH1.0/4.8 HD-SDI | 02YS(ST)CH1.0/4.8 HD-SDI | 02YS(ST)CH1.6/7.0 HD-SDI | 02YS(ST)CH1.6/7.0 HD-SDI | 02YS(ST)CH0.6/2.8 HD-SDI+2(2LIY0,14mm²(ST)DY+(3LIY1,5mm²)Y | 结构 | according to EN50117 | according to EN50117 | --- | --- | according to EN50117 | according to EN50117 | according to EN50117 | according to EN50117 | according to EN50117 | 内径 | solid copper wire 1 x 0,60 mm | solid copper wire 1 x 0,60 mm | solid copper wire 1 x 0,80 mm | solid copper wire 1 x 0,80 mm | solid copper wire 1 x 1,0 mm | solid copper wire 1 x 1,0 mm | solid copper wire 1 x 1,60 mm | solid copper wire 1 x 1,60 mm | solid copper wire (视频) 1 x 0,60 mm | 外皮,直径 | PVC 4,2 mm | FRNC 4,2 mm | PVC 6,0 mm | FRNC 6,0 mm | PVC 7,1 mm | FRNC 7,1 mm | PVC 10,16 mm | FRNC 10,16 mm | PVC (total) 12,7 mm | AWG | 23 | 32 | 20 | 20 | 18 | 18 | 14 | 14 | (视频) AWG23 |
| --- | --- | --- | --- | --- | --- | --- | --- | (audio) 2 x 2 x AWG26 |
| --- | --- | --- | --- | --- | --- | --- | --- | (power) 3 x AWG15 | 内径 | --- | --- | --- | --- | --- | --- | --- | --- | (audio) 2 x 2 x 0,14 mm2 |
| --- | --- | --- | --- | --- | --- | --- | --- | (power) 3 x 1,5 mm2 | 绝缘外皮, 直径 | Gas Injected-PE 2,8 mm | Gas Injected-PE 2,8 mm | Gas Injected-PE 3,7 mm | Gas Injected-PE 3,7 mm | Gas Injected-PE 4,8 mm | Gas Injected-PE 4,8 mm | Gas Injected-PE 7,05 mm | Gas Injected-PE 7,05 mm | Gas Injected-PE (视频) 2,8 mm
| 屏蔽层 | --- | --- | copper braiding tin-plated + AL-PT-foil | copper braiding tin-plated + AL-PT-foil | copper braiding tin-plated + AL-PT-foil | copper braiding tin-plated + AL-PT-foil | copper braiding tin-plated + AL-PT-foil | copper braiding tin-plated + AL-PT-foil | copper braiding tin-plated + AL/PT-foil (视频) + copper spiral 屏蔽层 (audio) | 电功每米 | 0,06 kWh | 0,06 kWh | 0,09 kWh | 0,09 kWh | 0,21 kWh | 0,21 kWh | 0,73 kWh | 0,73 kWh | --- | 传输长度 1,5Gb/s | (HDTV), 最低80 m | (HDTV), 最低80 m | (HDTV), 最低90 m | (HDTV), 最低90 m | (HDTV), 最低120 m | (HDTV), 最低120 m | (HDTV), 最低190 m | (HDTV), 最低190 m | (HDTV), 最低80 m |
| (HDTV), 最高100 m | (HDTV), 最高100 m | (HDTV), 最高120 m | (HDTV), 最高120 m | (HDTV), 最高170 m | (HDTV), 最高170 m | (HDTV), 最高235 m | (HDTV), 最高235 m | (HDTV), 最高100 m | 重量每米 | 22 g | 22 g | 40 g | 40 g | 64 g | 64 g | 106 g | 106 g | 200 g | 匹配插座 | 1-6051-2100-1 | 1-6051-2100-1 | NBNC75BLP9 | NBNC75BLP9 | 1-6052-2100-1 | 1-6052-2100-1 | 1-7048-2100-1 | 1-7048-2100-1 | 1-6051-2100-1 |
| BNC0.6/2.8HDTV-T | BNC0.6/2.8HDTV-T | NBNC75PLS9 | NBNC75PLS9 | BNC1.0/4.6HDTV-T | BNC1.0/4.6HDTV-T | BNC1.6/7.3HDTV-T | BNC1.6/7.3HDTV-T | BNC0.6/2.8HDTV-T |
| --- | --- | BNC0.8/3.8HDTV-T | BNC0.8/3.8HDTV-T | --- | --- | ---
| --- | --- | 1-6052-2100-1 | 1-6052-2100-1 | --- | --- | --- | --- | --- | 颜色 | 绿 | 绿 | 蓝 | 蓝 | 绿 | 绿 | 绿 | 绿 | 黑 | 类型 | --- | --- | --- | --- | --- | --- | --- | --- | hybrid | | --- | --- | --- | --- | --- | --- | --- | --- | --- | 线芯间电容 每米 | 53,0 pF | 53,0 pF | 52,9 pF | 52,9 pF | 53,0 pF | 53,0 pF | 52,4 pF | 52,4 pF | 53,0 pF | 屏蔽层阻抗每千米 | 17 Ohm | 17 Ohm | 20 Ohm | 20 Ohm | 7 Ohm | 7 Ohm | 10 Ohm | 10 Ohm | 17 Ohm | 屏蔽层 | > 90 dB | > 90 dB | > 95 dB | > 95 dB | > 95 dB | > 95 dB | > 90 dB | > 90 dB | > 90 dB | D.C. 阻抗每千米 | inner conductor 60,5 Ohm | inner conductor 60,5 Ohm | inner conductor 36 Ohm | inner conductor 36 Ohm | inner conductor 22 Ohm | inner conductor 22 Ohm | inner conductor 8,7 Ohm | inner conductor 8,7 Ohm | inner conductor 60,5 Ohm | | @100 MHz (per 100 m) 4 ns | @100 MHz (per 100 m) 4 ns | @100 MHz (per 100 m) 4 ns | @100 MHz (per 100 m) 4 ns | @100 MHz (per 100 m) 4 ns | @100 MHz (per 100 m) 4 ns | @100 MHz (per 100 m) 3,95 ns | @100 MHz (per 100 m) 3,95 ns | @100 MHz (per 100 m) 4 ns | 速率因数 | 0,82 | 0,82 | 0,82 | 0,82 | 0,82 | 0,82 | 0,85 | 0,85 | 0,82 | 最高传输长度 | (1,5 Gb/s) 65 m | (1,5 Gb/s) 65 m | (1,5 Gb/s) 95 m | (1,5 Gb/s) 95 m | (1,5 Gb/s) 120 m | (1,5 Gb/s) 120 m | (1,5 Gb/s) 170 m | (1,5 Gb/s) 170 m | (1,5 Gb/s) 65 m | 阻尼每百米 (20 °C) | 50 MHz: 7,3 dB | 50 MHz: 7,3 dB | 50 MHz: 5,8 dB | 50 MHz: 5,8 dB | 50 MHz: 4,5 dB | 50 MHz: 4,5 dB | 50 MHz: 2,9 dB | 50 MHz: 2,9 dB | 50 MHz: 7,3 dB |
| 200 MHz: 14,5 dB | 200 MHz: 14,5 dB | 200 MHz: 11,2 dB | 200 MHz: 11,2 dB | 200 MHz: 8,9 dB | 200 MHz: 8,9 dB | 200 MHz: 5,8 dB | 200 MHz: 5,8 dB | 200 MHz: 14,5 dB |
| 862 MHz: 31,1 dB | 862 MHz: 31,1 dB | 862 MHz: 24,3 dB | 862 MHz: 24,3 dB | 862 MHz: 18,9 dB | 862 MHz: 18,9 dB | 862 MHz: 12,8 dB | 862 MHz: 12,8 dB | 862 MHz: 31,1 dB |
| 1000 MHz: 33,6 dB | 1000 MHz: 33,6 dB | 1000 MHz: 26,4 dB | 1000 MHz: 26,4 dB | 1000 MHz: 20,8 dB | 1000 MHz: 20,8 dB | 1000 MHz: 14,0 dB | 1000 MHz: 14,0 dB | 1000 MHz: 33,6 dB |
| 1750 MHz: 45,2 dB | 1750 MHz: 45,2 dB | 1750 MHz: 34,6 dB | 1750 MHz: 34,6 dB | 1750 MHz: 27,5 dB | 1750 MHz: 27,5 dB | 1750 MHz: 19,0 dB | 1750 MHz: 19,0 dB | 1750 MHz: 45,2 dB |
| 3000 MHz: 59,9 dB | 3000 MHz: 59,9 dB | 3000 MHz: 46,4 dB | 3000 MHz: 46,4 dB | 3000 MHz: 35,2 dB | 3000 MHz: 35,2 dB | 3000 MHz: 24,2 dB | 3000 MHz: 24,2 dB | 3000 MHz: 59,9 dB |
| 2150 MHz: 50,9 dB | 2150 MHz: 50,9 dB | 2150 MHz: 38,4 dB | 2150 MHz: 38,4 dB | 2150 MHz: 30,3 dB | 2150 MHz: 30,3 dB | 2150 MHz: 22,0 dB | 2150 MHz: 22,0 dB | 2150 MHz: 50,9 dB |
| 470 MHz: 22,7 dB | 470 MHz: 22,7 dB | 470 MHz: 17,6 dB | 470 MHz: 17,6 dB | 470 MHz: 13,9 dB | 470 MHz: 13,9 dB | 470 MHz: 9,8 dB | 470 MHz: 9,8 dB | 470 MHz: 22,7 dB |
| 6000 MHz: 90,4 dB | 6000 MHz: 90,4 dB | 6000 MHz: 67,3 dB | 6000 MHz: 67,3 dB | 6000 MHz: 52,8 dB | 6000 MHz: 52,8 dB | 6000 MHz: 38,3 dB | 6000 MHz: 38,3 dB | 6000 MHz: 90,4 dB | 订货号. | | | | | | | | | |
605-0104-0628
605-0104-0628F
600-0-162
600-162F
605-0104-1048
605-0104-1048F
605-0104-1670
605-0104-1670F
605-0741
本贴表格过大,请下载附件查看完整表格。
散装线材_视频_RG_HD-SDI_HDTV_广播_视频_卫星线材.rar
(165.27 KB, 下载次数: 418)
